@ inside
Vale la pena montarli solo se hai in programma altri lavori alle sospensioni perché bisogna smontare quasi tutto, indicativamente penso 3 ore di lavoro (90?)
OT: cosa ? il CC :?:
@carbon
pi? che altro ? una raffinatezza; con l'assetto che hai gia tu
, penso che su strada li sentiresti davvero poco.
@carlito
sul sito da te riportato non ho trovato nulla.
su quello da me riportato c'? ne sono due versioni:
Versione 1
Energy Suspension Front End Control Arm Bushing SetEnergy Suspension Front End Control Arm Bushing Set makes a dramatic improvement in the way they handle?with quicker steering response and greater vehicle control. Whatever your demands, proper alignment (caster and camber) is better maintained by the use of the correct performance durometer of the bushing's material formulation. All of Energy Suspension's Control Arm Bushings are full-floating and non-binding, especially important when ride height is altered or greater suspension load is required. This is especially important for both lowered and raised vehicles that have had drastic suspension geometry modifications. Front End Control Arm Bushing Set maintains proper alignment under extreme conditions on and off -road and during competition. Also, it improves vehicle handling, cornering and overall control.
Note: All bushings we stock are in black color. These contain graphite which are self lubricating for less maintenance.
27.35$
Versione 2
Energy Suspension Hyper Flex System Complete Master Bushing SetEnergy Suspension Hyper Flex System Complete Master Bushing Set both restores worn mounts and bushings as well as adds a dramatically higher degree of performance to any vehicle. These Master Bushing Sets offer complete coverage front to back of the vehicle's chassis. Energy Suspension's special formula HYPER-FLEX? performance polyurethane components, which is higher durometer (firmness) material and reengineered performance-minded components, assures long-lasting performance in all sets. Performance many O.E.M. bushings and mounts just can't offer.
For cars on the street and weekend racers (both front and rear wheel drive), yet so good?successfully used in pro racing!
? Get real performance?for both on the road and off.
? Popular performance car, truck and SUV applications.
? A real must for competition use- or just for that "seat-of-the-pants" fun!
? Increases vehicle stability and control as well as durability.
? Reduces wheel hop and traction loss.
? Proven?for many years, by both professional and amateur racers alike.
? Both restores and improves better than new!
? Made of Energy's HYPER-FLEX? performance polyurethane.
? Heavy duty metal components are used?for increased strength, when applicable.
77.78$
Da quel che ho capito il primo ? per lo STERZO mentre il secondo ? per le sospensioni Giusto :?:
