http://www.brashboy.net/english/toyota/zzt_celica/op_index.html
Kit includes:
■ A crank shaft (Balanced and straighted)
■ OEM Modified connection rod.
■ An oil pump spacer
■ An oil jet spacer etc
Price 312,900 Yen
Kit includes:
■ Original H section connection rod
■ An oil jet spacer, etc.
Price 417,900 Yen
Low Compression Piston for 2ZZ (for Super Charger or Turbo)
ZZT230/231 148,000 Yen
4 POT BRAKE KIT (ROTOR φ296)
ZZT230/231 365,400 Yen
hort ram air intake kit(Heat protection cover included)
■ PIPE, AIR CLEANER, SILICON HOSE, BAND
■ Blocks heated air from the engine.
ZZT230/231 26,040 Yen
ORIGINAL OIL COOLER
Oil temperature easily exceeds over 250 fahrenheit in race track use. Over heated oil causes VVT-i and VVTL-i malfunction and possibilities of engine blow in worst case.
ZZT231/ZZT230 FULL KIT 93,450 Yen
HOOD SCOOP
ZZT231/ZZT230
■ FRP 20,790 Yen
■ UNPAINTED/WET CARBON FINISH 31,290 Yen
■ OEM COLOR PAINTED 26,040 Yen
Oil pan with baffle
Prevent the inclination of the engine oil.
Protect an engine
for ZZT231/ZZT230 62,790 Yen
Rear Brace bar
Install it into the trunk area to reinforce rear section of the body.
for ZZT230/231 24,150 Yen
Side Tower bar
Place the side tower bar and make the body perfectly ridged.
for ZZT230/231 27,300 Yen
Original Brake Shoe
More stopping power than stock pads. Rear break pads from Endless for ZZT230.
for ZZT230 24,150 Yen
Brake & clutch hose
Stainless steel mesh hoses gives you a direct feeling to your foot and more stopping power.
for ZZT230/231:
ndependent MacPherson strut front suspension 28,350 Yen /MT
26,250 Yen /AT
for ZZT231:
ndependent Super strut front suspension 39,900 Yen /MT
36,750 Yen /AT
IN・EX valve
Reinforced valves. OEM valves are weak, bends and breaks.
for ZZT231 For one unit 102,900 Yen
komatsuda@brashboy.net
BRASH・BOY
2-1-2 hosoda,katsushika-ku, Tokyo 124-0021
TEL.+81-3-5698-3582 (Japanese Only) FAX.+81-3-5698-3583
